Regarding the OFH - What sensors are actually used?
alansupra94
Wayne,NJ
I was wondering what exact sensors are used? Do they both need to be there or is one of them only used in the 1G T/E/L?
I am looking to take in for a oil pressure sensor for my Greddy Gauge.
EDIT:
Here are the two sensors:
This is where they sit (on a watercooled OFH the air cooled one they sit a bit different)
jepherz
KC, Missouri
You'll have to post up pics to make sure, but from my recollection, DSMs use a large sender for the oil pressure gauge, and a small one for the dummy light. Since galants don't have a pressure gauge, they only need the small one.
alansupra94
Wayne,NJ
I thought so too...does the ECU log oil pressure through the gauge or dummy light or none at all?
I will snap pictures tomorrow.
There is no logging of the oil pressure switch or sender.
The threads in the OFH are 1/8" BSPT for the switch and 3/8" BSPT for the sender on DSM's.
As was already mentioned, the GVR4 does not come with a sender stock but does have a 3/8" BSPT plug at the bottom that can be used.
alansupra94
Wayne,NJ
Sweet. I will be keeping that in mind.
Looks like that massive bell/umbrella sensor is the pressure sensor while the other one is the dummy light. Someone correct me if they think I am wrong.
Thanks,
Alan
That is correct. The small one in the front is the switch and the large one coming off the bottom is the sender.
dsmtalontsi95
Glenville, PA
Here you go. They didn't used to make them till about a year ago when I had them make me one. They are an awesome company and if you need them to make any lines they will help you out.
