Rear drive shaft U-joint
gvr41190
Active member
Richmond, IN
I've got my drive shaft off and noticed that the rear u-joint is binding a little. I'd like to replace it, so I looked on Mitsubishiparts.com. It just shows "universal joints" and doesn't give specifics. Could anyone please provide a part number or other guidance? I really want to make sure that I order the proper piece.
Also, I need to replace the vent on the diff, but didn't see it listed. Any help finding this would be appreciated, too!
Thanks in advance.
Muskrat
Lexington, KY
Buy the drive shaft yolk kit, and pull the u-joint out of it and use that. OEM u-joints are stronger than the aftermarket, but really expensive on their own (over $100 iirc). but the Yolk kit, which comes with one, is only ~$35.
