ercp98
for those who have replaced the stock 3 bolt rear diff on the vr4, how did you access the
two bolts on top of the rear diff? can it be done with out dropping the whole
rear subframe? i only have taken a look and have not tried to get to the bolts.
it looks very inaccessible unless the subframe is removed too.
which side of the 3bolt lsd rear diff takes the longer axle shaft?
thanks in advance.
thanks in advance.
