Rear diff. Bearings/ Solved
Nabeel
K.S.A
I am to replace the rear diff bearings. I sow only 3 bearings in the stock diff. while it show 4 bearings at CAPS.
Two at the sides & two at the pinion. Rear & front. I find only at the rear of the pinion when I take it off out of the diff. Any one can confirm how many bearings are there?
I was mistaken. (There are 4 bearings)
curtis
Clarksville TN
Ok make sure you set it back up at the same spec's as it was and make sure the wear pattern is the same or your its going to talk or worst eat itself apart. I've found over they years mitsubishi has much higher machining tolerances compared to a Ford or Chevy so you'll probably will be alright but alot of companies don't so always measure everything even the depth the bearings sit in the races.
