Radiator question
Steve885
Concord ca
So Ive been having a little trouble keeping things cool...thought I had a stock radiator can anyone answer me this .does our cars radiator have a A/t fluid reservoir built in to it .. I suspect not but thought I'd ask anyway.
transparentdsm
Cherry Hill, NJ
it could also be a clogged heater hose or heater core, bad water pump or bad thermostat. take the whole system apart and flush and back flush everything till the water comes out crystal clear.
Steve885
Concord ca
It's always been a issue...more so now with the new setup,cams,20g link and tune I've tried everything,,coolent no coolent 160 180 thermostats it's always the same in warm weather I can't keep it under control it dosnt over heat but it gets into that 220 range then starts to idle super high. I think my intercooler may be a problem it's way to big for a street car...I might go with a smaller one
MellowVR4
Milwaukee, Wi
I've got an AFCO radiator, two fans on toggle switches, redline water wetter. On hot days I still have to keep the fans on most of the time just so it doesn't go over 190, specially on the freeway. I think by getting the fp blanket for my exhaust manifold is going to help out a bunch. It only make sense that it does.
