question about measuring push lock line...
SleepinGVR4
Danville, Pennsylvania
Is there a way to figure out how much push lock line shrinks when pushed onto push lock fittings. The reason I ask is I'm going to fix my oil drain on my turbo and I'd like to "measure twice cut once," if you know what I'm talking about. Since the distance from the turbo to the oil pan is pretty short its easy to cut the line too short.
Muskrat
Lexington, KY
What do you mean, "shrinks"?
Just mount your two fittings to the turbo and oil pan,then use a piece of wire measure from the flange on 1 fitting to the other, approximating the shape the tube will be taking.
Measure the wire length, then cut a but longer than that and test fit. Remove material as needed. (note, once you install the tube on push-lock fitting it'll be very hard to remove. only install 1 side when test fitting and line up the other. You should be bale to get a good idea.)
SleepinGVR4
Say you cut a piece of hose and measure it. Once you put push lock fittings on both ends the hose is shorter due to the fact that it has to stretch to get on the fittings.
I've never tried the wire method you described. I usually just attach the hose to one fitting and eye ball it to the collar of the other fitting and mark it and cut it a little bit past the mark I made.
curtis
Clarksville TN
Get a piece of cheap hose/ garden hose that is the next larger size and cut and trim till it is perfect then cut the smaller good hose to fit.
Muskrat
Lexington, KY
Quoting SleepinGVR4:
I still don't understand what you mean. I've never had the hose change in length after installing push-lok fittings. In fact, from what I remember push-lok hose doesn't really stretch, period.
