Question about evo mr suspensions
Sam
Member
Riverside, CA
I have the MR bilstein with swift springs and about to cut the stock bushing to weld to it.
But before all that, does anyone know how low it will sit compared to the front if its welded all the way up?
Thanks
pot
Fayetteville, NC
Hi Sam! Welcome to the galant board. I have attached a link below to give you a general idea of what the process will look like to convert your existing suspension to an Evo XVIII - XIV MR suspension. Please see here:
There is plenty of useful information on this board dealing with this subject
Sam
Member
Riverside, CA
I just wanted to know if the rear would sit lower than the front. I went ahead and did it already and the rear sits a bit lower. But not enough to notice if youre not paying attention to it.
tektic
ronkonkoma, ny
What springs are you using? If people swap with stock springs they cut a coil off the front usually. Did you try searching? There’s like a dozen threads on this.
BLUELIGHTSBABY
Franklin, NC
"EVO 9 MR SUSPENSION ON GVR4 10/21/12" I did a write up on mine with pictures. You will have to search the forum under the technical information forum.
