Partout: 247/2000 white - crashed
NateCrisman
Blairstown, NJ
Just got ahold of a white 91 GVR4 to part out, unfortunately, it's absolutely totaled.
youtube video of engine running and quick walk around
List will be updated as I pull parts and get photos processed. Anything specific not listed...please just shoot me an email: [email protected] or TXT 862 251 2571...
If you guys want to kinda "call dibs" on stuff...go ahead and comment to this thread to mark your territory <img src="/ubbthreads/images/graemlins/rofl.gif" alt="" />
<b>Aftermarket Parts:</b>
Apexi EL EGT gauge $65 (I don't see the probe, so you'll need to buy a K-type)
Apexi EL boost gauge $50 (I think this is electronic w/ map sensor)
Apeci AFC - $150
Pioneer DEW P8400 head unit $100
Wheel/Tire: Enkie 17" w/ Brigestone potenza 215/45/17 - Sad..these were literally only on the car for a few days before the crash. Pass front wheel is trashed &amp; tire is cut. PM me if your interested in the partial set or I'll see what cost is going to be to replace the un-useable wheel and maybe refurbish the one w/ curb rash. Tire rack has the wheels for $147 each for 17x7" 4x114.3 38mm offset. New matching tire is $118 also from tirerack.com
Perfect wheel/tire (Driver Rear):
Wheel w/ minor scratch (Pass Rear)
Curbed Rash wheel (Driver Front)
Photos and more information to come, but these are preliminary price and I think mostly complete list
HID Headlights/Foglight stuff 100
Eprom ECU w. TMO stg3 chip 250
turbo timer 50
NGK plug wires 25
Catch can 25
non cruise throttle cable 20
3G maf w/ filter &amp; plug 50
Spal 12” push fan 40
16G turbo, ported 2g eh manifold, &amp; ported 1G o2 Housing. (pics shown still on engine)
Prefer to sell as an assembled set at $300 w/ oil &amp; coolant lines.
550 injectors 125
BM FPR 35
ACT2600 w/ street disk, &amp; tob $250 Prev owner says this has very little mileage
SS clutch line 35
Eibach Prokit lowering springs (1g awd i'd guess) 50
<b>Stock Parts:</b>
Gauge cluster w/ 89k miles $75
<b>Electronics: </b>
Engine - ECU harness 150
chassis engine bay harness 100
Chassis interior harness 125
coil pack 35
Igniter module 35
Cam angle sensor 35
alternator 25
fuel pump sending unit 75
o2 sensor 15
(there are TONS of little relays/fuse boxes, control boxes, and interior electrical items that will be for sale)
<b>Engine &amp; Drivetrain: </b>
Trans $325
23 spline XCase $85
GVR4 3bolt diff/axles &amp; 4-wheel-steering rear assembly w/ subframe &amp; lines 350
shifter cables 20
Fuel Tank 50
driveshaft 10
Complete AC system: evaporator, compressor, brackets, hardware, lines, fan. "everything" $300
<b>Suspension - Brakes </b>
Dual piston front calipers 75
Ebrake cables 50
rear brake calipers 25
Good front rotors - pair 25
4lug hub driver front 25
4lug hubs rear 50
ABS pump 100
<b>Interior</b>
Rear leather seats: no rips or tears $50
Carpet 20
AC and heat controls 20
center AC vent 25
door panels 45
roof lights, steer column cover 15
headliner 25
door lock knobs 10
sun visors 5
<b>Body &amp; Exterior</b>
Rear Bumper 75
Grill 50
driver dogleg 20
corner light - driver side - clear type $25
driver fender 50
Door moldings drivers side 20
driver fender molding 25
Body skirt driver side 10
rear window molding 25
windshield wipers 10
antenna (not sure if works)
gas fill door 5
<b>SOLD LIST</b>
3" turbo back Exhaust - $350-P (local dude picked it up right away..i was hesitant to ship it)
Front seat set $100-P
F&amp;R Seatbelt set $50-P
Throttle body w. TPS/stop switch $45-S
Trans/Xcase $400-P
Center console, gauge pod, wing - $20-P
Dejon intake pipe $50 S
Alternator $35 S
Fidanze flywheel $130 - S
Dash badge 247/2000 $125 - S
A pillar &amp; B pillar plastics - $40 - S
TMO Chip - $40 - S
Injector Resistor - $5 = S
HKS cams $300 p
6 Bolt engine. $540 p
Tail lights $75 s
sunroof assembly 40 p
Dashboard 40 p
autocrossn
Member
onalaska,wi
Driver side fender and trunk as long as there in good shape and no rust
Guess it depends where the damage was from accident
NateCrisman
Blairstown, NJ
Going back to shop tonight after dinner to check more stuff, disassemble more, get more photos and info. Im going to keep the first post updated as well as I can. /ubbthreads/images/graemlins/wink.gif
4g6Tree
Active member
Salem, VA
Interested in cams, FMIC, and exhaust. Can you get me pics and a price for all of it shipped to 24153?
GVR4ZUM
SoCal, USA
Hi Nate,
What is the condition of the 4WS hard lines? From the looks of the underside pics, they maybe rusted. /ubbthreads/images/graemlins/frown.gif
Please see my post. 4WS
4WS Hard lines
NateCrisman
Blairstown, NJ
FMIC: There are about 4 or 5 people that have expressed interest in the fmic kit...I'll have to go through them and check time stamps to see what the order is. Please be patient with me guys, still working full time job for another week or so before I quit that and go back to parting cars full time, then I'll be quiker with turnaround.
Quoting dime2nr:
Drivers dog leg
Cluster trim
Column surround
please
Will pull tonight specifically for you
Quoting autocrossn:
Will check rust condition on the fender tonight after fender molding comes off....It looks good from outside. Trunk looks rust free but has a ding in the skin (like someone shut trunk with something too tall inside)
Quoting GVR4ZUM:
Hi Nate,
4WS Hard lines
I'll do my best to recover the entire 4WS system without breaking any fittings or lines, I think it will be ok. will soak fittings in penetrating oil tonight and let sit for a day to hopefully help.
PolskiVR4
Lemont, IL
I didn't see this thread. But I messaged you about the fmic after you replied to my wtb post. Posting this so I can get on the fmic list lol.
old4door
Member
Spring, TX
I need the rear subframe brackets, the ones in this picture that connect the front mounting points to the body. How much shipped to 77373?
AWD_DSM
East Grand Forks, MN
Dibs on the hood latch assembly, under hood fuse box cover, trunk and gas door release cables with levers, dash cluster, and the drivers door panel.
NateCrisman
Blairstown, NJ
Ok...got motor/trans out yesterday afternoon. Today Im going to shop with goal of just pulling parts that you guys are all asking for...body, interior/exterior trim, ect. I'll be contacting you all directly after dinner to setup paypal payments and get shipping addresses/quotes.
Sorry for the wait...."day job's a bitch" but soon I'll be back to parting out full time. /ubbthreads/images/graemlins/devil.gif
GVR4ZUM
SoCal, USA
Quoting GVR4ZUM:
Hi Nate,
4WS Hard lines
GetWrexed
Member
Arvada, CO
Dibs on rear windshield molding/trim. Will update this with more parts needed once I get to my Galant later today.
