Output shaft that goes from AWD transmission to transfer case
BLUELIGHTSBABY
Franklin, NC
Ok guys, I have a question about the output shaft that comes out the bottom of the transmission and goes into the transfer case.
Is this shaft suppose to just pull out? So what I'm saying, when you drop the transfer case, can you just grab the output shaft and pull it out the transmission??
I can, and I was concerned it was supposed to have a clip or some lock that goes on the other end that goes inside the transmission.
I have an automatic AWD trans in my galant VR4, but I don't recall if the shaft pulled out freely from the manual transmission or not.
Thanks for any knowledge you can share.
CutlassJim
Manchester, NH
I've never worked on an auto but on a manual trans it is not supposed to. There is a ball bearing that gets captured by the center diff viscous coupler that usually makes it so you can't just pull the output shaft out.
gvr4ever
central Indiana
2nd, it doesn't come out on the manual. Can't say for sure on the auto, but it doesn't sound right that it does on yours.
BLUELIGHTSBABY
Franklin, NC
Thanks Guys. Trans has been running fine, it's currently out of the car, and Ill be dropping the pan this week and Ill report what I find.
brisvr4
brisbane australia
The auto trans output shaft normally has a clip on the end the same as the passenger side axle on a manual car. Mine is long gone and I don’t have any issues!
CutlassJim
Manchester, NH
That's cause in Australia toilets flush the opposite way and that's keeping the output shaft in place on yours. Up here in the northern hemisphere we super need the clip to keep the shaft from exiting stage left(right?).
