That looks almost identical to the one i got.
Mine is fabbed from a spearco 2-120 core, and was purchased from MachV. I cut the passenger side pipe across the bottom and bent it down a bit, then had it re-welded after getting it at the angle i needed. The way it came, the exit pipe just stuck up at too far of an angle and would have likely caused some fitment/interference issues with the 4" intake pipe. I also cut off the mounting tab and had it welded where i needed it to bolt to the hood support bracket, so that i could have the IC sit dead center in the bumper. It fills the hole in the (cut) USDM bumper perfectly from top to bottom.
Oh, one other thing. The TB elbow that came with it wouldn't clear the CAS or water neck very well, so i wound up ordering a stainless one with IAT bung from ETS. I honestly didnt use ANY of the plumbing it came with, because i wanted all stainless rather than aluminum. It weighs a bit more, but it polishes up nice and doesn't oxidize nearly as quickly or as badly.
(I just looked at the tooners link, and it looks like it might be the same FMIC i got, but mine came without any BOV flange. Couplers and clamps look the same.)
