324vr4
so 324 is about put back together and i have a problem i can't figure out. got the timing belt all set and the car was idling for about a 1/2 hour. when we turned off the car, the timing belt was loose, really loose. we called it a night and got back after it this evening. after rotating the crank to get everything timed in preparation of removing the belt, the belt re-tightened itself. i checked the tensionor gap and it fell at .17, well within spec. what gives? is this normal behavior for the tensionor, or is it on it's way out? it's brand new, but not oem (it's napa, i know, i know...) thanks! it would be nice to get the car running again tonight!!!
