CarRacer
I have a severe leak from my turbo oil return line. One of the bolts in the pan is stripped out. I guess the PO didn't understand torque values.
What are my possible fixes? My searching here says most recommend installing a AN fitting setup. I'm not going to spend money on replacing the 7 bolt oil plan. Pissing away $75 on a motor I don't want is not an option. Is a heli-coil a possible fix?
Thanks.
Thanks.
