blacksheep
This is an age old question and I am unclear on the answer.
This is a general question although it pertains to the Evo as well.
There are 2 options as mentioned above:
1) Tap sender into the head (Evo has a hex bolt when removed allows a sender to bolt-up)
2) Tap sender into oil filter housing (Evo has hex bolt when removed allows a sender to bolt-up)
But, I am sure at the head pressure reads lower than at the filter. So, question remains:
Which is better or lesse of the two evils?
I assume one loses oil pressure at the head first when the pump goes, yet people seem to argue that this is a location for oil feed and the oil filter is better.
Any advice appreciated!
Thanks!
Thanks!
