belize1334
OEM main bolts are good to about 500hp but when paired with a girdle people have clearance issues so the kiggley main girdle REQUIRES arp main studs, which have a lower profile at the top due to the 12pt nut.
The OEM main bolt set actually comes with a single stud that, I presume, is used for mounting the oil pickup tube? see pic
If instead of running 9 bolts and one stud we were to instead run 10 studs (and if necessary swap in 12pt nuts) wouldn't that accomplish the same thing as with arp hardware vis-a-vis clearance but without necessitating a line-hone for the main caps? Does anyone have a part number for that one stud?
