I will be using an external wastegate that I was planning on re-routing back to my exhaust, eventually. I was thinking of doing this about where the DP bend is...
However, the bung for a wideband O2 sensor would be before joining the exhaust back in...I noticed the factory O2 housing (EVO 3, fwiw) has the O2 sensor placed to where the WG gases do not go past this; that is the 'regular' O2.
So, the question(s) is: On a WB O2 sensor, would it make any difference if the WG gasses do not pass this sensor and/or what does the O2 sensor (WB) read anyhow (percentage only); is there any advantage running it by there, for tuning and such?
Thanks,
John R.
Thanks,
John R.
