O2 sensor question.
Vr4door
Member
AZ
When you hook up a wideband to link in a 1g do you completely cut the stock narrow band wire out and not even us it? Or do you just splice the wb into pin4 while also keeping the stock o2 still hooked up to the ecu? Is there a way to wire in both the stock nb o2 and a wb o2? So I won't have the run narrow band simulator? I already mounted my wb o2 36in from the turbo so I have both sensors in the car already and would like to keep ot that way. I am running the aem uego wb kit and link v3.
Coltsfan
Tonawanda
Wire it to the EGR temp input (pin 15), and use it for logging only. Or futz with trying to replace the narrowband and get it set up to do narrowband simulation. In my opinion the only reason to do the latter is in case you want to calibrate a leaner cruise AFR.
MellowVR4
Milwaukee, Wi
I'm am going to do this too, at the moment all I have is my wideband simulating the o2. This would definitely work out better I think. So pretty much I install the stock o2 in it's original home( the o2 housing ) and keep my wideband on my downpipe for tuning and keeping an eye on my mixture.
