Non turbo water pipe part #
they dont make them anymore i have one brand new for sale if you want it... pm me
RedTwo
New Zealand
If we're talking about the same part...
There's 1 part number for early '90, 2 for mid '90 and 2 for all years after that.
Try MD136572 for starters.
I'm only coming up with two part numbers
up to 9/90 is MD136572
after 9/90 is MD171058
Dialcaliper
Bay Area, CA
Are you looking for the Nonturbo or the 90 DSM turbo water pipe?
If you're actually looking for a nonturbo pipe, the two numbers above are correct. (the pipe is probably the same - if you check CAPS, the new one probably superceeds the other.
Check them here
However, if you're actually after a 90 turbo pipe:
MD147684 PIPE ASSY, WATER $43.05
Just ordered one of these from JNZ earlier last year, and it is the correct '90 part (w/ water line for turbo, but not for pancake)
Dial Caliper is correct. The other 136572 part number is non-turbo, so no water outlet for the turbo. Will work if you are looking to run a non-water cooled turbo.
Or looking to weld a AN bung elsewhere on the pipe for water feed to the turbo. I used a non-turbo water pipe on my car, welded on a AN bung and a nipple for the hose that feeds the pancake.
