No thermostat plugs on harness - need help rewiring
Number996
Gaithersburg, MD
Finally swapped my newly built motor into my galant. I can get the engine to crank by jumping the starter (because i think starter relay is bad) but not fire so i'm slowly addressing all my electrical problems.
All of the thermostat plugs have frayed and broken off from the wire harness. I was able to salvage an AC switch plug and Coolant temp plug; the two double prong plugs, one (II) the other (I--). I can make plugs for the two single prong connectors.
My first question is: will these plugs prevent the engine from firing if they are not wired?
My second question is: what color wires go to which plugs? The color scheme of the 6 wires from the harness for thermostat is as follows:
- x2 green wire with black stripe
- x2 yellow wire with green stripe
- blue wire with black stripe
- green wire with red stripe
My third question is: if these wires aren't hooked up could it cause the ecu to block a signal to the starter preventing the engine from cranking (this would mean that my relay is fine and thats why the engine wont crank when i turn ignition forcing my to jump the starter directly by connecting power feed on started with solenoid connector manually)?
Any help is appreciated i'm so close to getting this gvr4 back on the road where it belongs. Thanks guys
Number996
Gaithersburg, MD
Still lookin for accurate info regarding color sheme of thermostat plugs, more spacifically the engine coolant temperature sensor. But the more pressing question i need answered regarding this problem is;
If the Engine Coolant Temperature Sensor (the lower T shaped plug on thermostat) is not plugged in/wired improperly, would that cause the ecu to prevent the engine from cranking?!
NO. Disconnecting any of the sensors (or having them plugged in incorrectly) you mentioned will still allow the car to crank. I had a similar problem with my coolant sensor harness being all jacked up. Eventually, I figured it out. I'll outline exactly how, later tonight when I get home from work. For now, read here click
toybreaker
iconoclast
If you have any additional questions, pm me your phone number and I'll walk you thru a few simple tests to ensure everything gets hooked up correctly.
