needing coolant reservoir... which one?
When I purchased my vr4, it did not have the stock coolant overflow reservoir and I'm wanting to know if it uses the same reservoir as any other cars. (ie. 90-94 dsm, other galants, etc.) I can't seem to find any other info, so if someone knows if i can use another car's reservoir or know of a place to find one, I'd greatly appreciate it becuase I'd like that to still be stock. Thanks
misterfixit
Midlands, UK
SAME AS ON A REGULAR GALANT WITH ABS. just need an e30 one. pushes onto a little angled bracket that bolts under the fender rail and under the abs pump mounting bolt.
Hope this helps,
Rich
