Need advice from people who remember mofugas stuff
VR6Eater
Bristol, WI
So the question has come up, what's the difference between the gvr4 stock shifter, tel, and mofugas shifter. If memory serves me correctly, stock is tall, tel is shorter, mofugas is stock but the throw is short due to mods on the bottom. A cut gvr4 stock shifter is about the same as a TEL. Anyone that knows for sure, please speak your mind. /ubbthreads/images/graemlins/banghead.gif I don't remember.
turbohf
Lake Stevens, WA
speak my mind? TEL shifter is junk. first thing i did to my Galant was remove it.
i dug around, all i found was a pic of the stock TEL shifter, and my modified shifter. but the whole bottom section has the same dimensions, having the same throw.
curtis
Clarksville TN
Thats pretty much the differences. I've modded a bunch of these over the years and built them with adjustable stops like the hurst etc in the Mustang Camaro etc. Cut the handle position where you want, then below the pivot point I cut and add steel and brace then on the next piece I cut below the handles pivot point and above the next pieces pivot point and add steel. After that weld on a piece of steel that wraps around the shifter handle and install two bolts with holes that are tapped and jam nuts on each side to keep everything in place. If i remember correctly he used other factory parts to get the same outcome. Believe it was a 3000gt second piece. But just easier to cut and weld on a piece of thick steel.
Here's a link of info
