N00b question on 5 lug swap.
cupajoe
Cocoa, FL
I found some 5 lug rims for dirt cheap but there 5 lug. I have a 91 dsm parts car so I'm thinking about picking them up and doing a 5 lug swap. My only concern is the front brake calipers. 91's don't have the big brake upgrade and our vr4 do. So will my front calipers still bolt up? or will I need to swap over the calipers also?
cupajoe
Cocoa, FL
Thanks, I pulled the tire off just to get a good look and from what I can tell I wont be able to keep the aws if I swap out the rear hubs? For the people that keep aws with a 5 lug swap you guys have to press out the hub? and slide the 5 lug onto it?
cupajoe
Cocoa, FL
In order to keep aws am I going to have to press the hub off to swap it? Because the hub has a bar connected to the frame but has the tab where the aws rack hooks up to it. And it seems to be all one peice so If I swapped that out there would be no tab to bolt the aws rack to. Or maybe Im not understanding...
cupajoe
Cocoa, FL
Ok ok, after looking at some more threads, Im just pulling out the rear spindle and replacing it with the 5 lug spindle? Any special tools I'll need to pull out the rear spindle?
cupajoe
Cocoa, FL
Alright I just looked at the rear hub on the dsm and looks like there is that same tab there to where I can just bolt the aws rack to. Is this how everyone else does it? or do you guys only swap out the spindles?
bazeng
Melbourne, Australia
spindles on mine!
There are a few threads on it already buddy.
I've posted up a bunch of pics on how I did mine.
I can't remember the name of the thread though...
Spindles only. I think there's a 21mm (don't really recall actual size) nut holding it in from the back of the hub.
cupajoe
Cocoa, FL
Thank you very much for clarifying that for me. Guess I'll also be doing a abs delete sense he dsm doesnt have them.
jepherz
KC, Missouri
The ABS parts can all be swapped over as well. You'll see the "gears" when you pull the rear spindle out.
H05TYL
Wgtn, NZ
Quoting bazeng:
spindles on mine!
I was looking at this just last night, I searched +5 +stud and user = bazeng and found it easily.
According to vfaq the nut is 27mm - I'm just in the process of removing my rear spindles (I'm getting them redrilled as GTO/diamante ones have proved hard to find) and got caught out by the lack of a 27mm socket in my toolbox /ubbthreads/images/graemlins/banghead.gif
