mooserage
So, I used the instructions in this thread: click and checked two MPI relays that both came up perfect. But when I try to start the car it won't start, the fuel pump relay is not getting 12v. If I jump +12v to the fuel pump relay (bosch relay rewire) it will start fine. I am also running AEM and not a stock ecu. So, I have come to the conclusion that there may be a problem with the wire that runs from the MPI to the relay to turn it on. I am wondering if anyone knows the pin I can check on the MPI connector for continuity back to the wire that turns the relay on. Any help would be great, thanks guys.
-shamus
p.s. For anyone wondering why I wouldn't just continue to use a switch to manually turn the pump relay on and off there is a very good reason. One of the functions of the MPI relay is to cut the fuel pump if the engine should stall, this is an important safety measure. If I were in a rollover or any accident and the fuel lines ruptured, the still connected battery would continue to run the fuel pump, spraying fuel all over an accident. this is the biggest reason I would like to get this situation fixed, simply for safety. Thanks.
-shamus
