motor mounts
cheekychimp
East Sussex, U.K.
You mean the one that bolts to the transmission?
I am pretty sure that 1G front motor mount inserts are the same size as the 2G rears (i.e. 2.78" diameter by 1.5" wide). I have never used a 2G front engine mount, so I don't know about that one.
I know this isn't very helpful, but what I am saying is even though the pictures look the same, I'm pretty sure if you buy a 'set', then 1G motor mount and 2G motor mount dimensions are going to be different.
pmp285
manila,philippines
i mean cam side mounts...
my tranny mount is same as a 1g though... engine is an evo3, i didnt use the 1g engine mount on the cam side
are the energy suspension engine mounts pressed or cut in half?
im really getting confused on what to get
I would get the 1g kit first. That way you'll get three right for sure. The side mount (timing belt) could be the same, maybe not. If not you can order a single 2g insert to fit. You may want to take measurements of the mount hole first to confirm fitment.
Also yes, all bushing are split in half and will slide in without a press.
strokin4dr
Savannah, GA
Post some pics of the 2g mount in a vr4. Did it bolt straight in without relocation of the through bolt? I doubt it.
cheekychimp
East Sussex, U.K.
I am pretty sure the 2g mount will Not work in that location and will make your engine higher on the cam side if you do install it. Are you simply talking about using the rubber/polyurethane bushing and installing it in the original bracket or using a 2g bracket? If it is the latter I'm sure it won't work but the former I am not sure. I don't know the diameter of the cam side bushing on the 2g.
manikbastrd
The front (press in) and right (cam) side (2 piece) from prothane (for a 1g) are the exact same as VR4. I can't remember if the rear and tranny are as well, but I recently did them and they are the same. The only things that suck are getting the old ones out (I use a reciprocating saw and some chisels) and putting the press in one in (I just used my vice and some patience).
pmp285
manila,philippines
i have no problem with the front, back and tranny mounts.. all are from a 1g. just the cam side mount, im not sure if its the same size as a 2g, since evo123 is a 7bolt
