Manual steering rack and automatic shifter questions...
so i have some plans for my gvr4 and had a couple questions.
I am trying to clean up the engine bay as much as possible and want to get rid of the power steering and such. Will a 1g manual rack bolt up fine or do i need to find one from an old base model galant (if they exist). Also, i am going to convert to auto-tragic and my only concern is the automatic shifter. I am guessing since 1g manual shifters bolt up fine and automatic shifter shouldnt be a problem? I just picked up a donor 1g awd auto parts car with a 4 bolt LSD so i want to make sure i have all the parts needed to get this project done. any tips/advice is greatly appreciated. thanks.
chris
i tried... the search function sucks on these boards. Or i just am not using it right. thanks though. /ubbthreads/images/graemlins/smile.gif
brisvr4
brisbane australia
It can suck!
Easiest way to find stuff is to put a + in front of each word.
I just typed +manual +rack .
You can also convert your PS rack into a manual rack of sorts by pulling the rack apart and removing the piston from inside it.
It will be pretty heavy on your arms if you do it like that though!
I've gotten used to mine that I converted but I wouldn't advise trying any tight road courses at speed with it.
