Mangus heat barrier intake mainfold gasket...
onesickcrx
NY
Mangus heat barrier intake mainfold gasket. I am intrested in one of these anyone have any experance with one? Likes dislikes? I can't imagine this not working but any info would be great.
onesickcrx
NY
Installed it with nothing else other then gasket? No RTV or Hylomar or 2 stock gaskets with mangus in the middle? What kinda of power levels are you running and how much boost?
shredder2010
Racine,Wi
I just installed the gasket not rtv or anything. Right now only 20psi. Im not aure bout hp wise maybe around 325ish, but ive had no problems with it i plan on going to e85 and crank it to 25psi.
DynastyLCD
Harwinton, CT
ive tried the magnus, slowboy, and extremepsi ones. all of which were installed with no RTV or sealant of any kind. all holding 25+ psi, some reused, all good luck. would definetly recommend especially if you plan on swapping manifolds at any point in time.
