OK, this may be a silly question, but was thinking about this the other day...
When you use water or (esp.) methanol injection, does this cause any issues with respect to what volume the ECU thinks is there? I mean, you are adding some volume there (beyond what the ECU 'knows' is there) and say when the water turns to steam wouldn't there then essentially have some additional oxygen (from the water) in the mixture? How about methanol since some of it is then fuel? I imagine the air is denser from being cooler (the water content to steam in both types), but I am curious if there is a way to compensate for this, or perhaps there is no issue to be concerned with?
I haven't *heard* of any real problems with WI in respect to this, but wondering if there are some more improvements to be had with better correcting the actual A/F ratio with respect to the ECU...
