Quoting BENE38A:
i am trying to establish what diff my 91 vr4 rs has the label is pretty hard to read but it has a C1Y then underneath it has 3.909 but cannot read the above. is it a viscous or another type of lsd, ive searched high and low but cannot find much im buying an evo 3 rs gearbox and transfer case and to my understanding it will work fine with my 3.909 rear lsd, this car is jdm has 4 bolt rear etc will the axles i get with it work or will i have to put an evo3 diff inside my diff housing to use the axles, will update when i fit it up but a heads up now would be good damn evo3 rs stuff is pricey but my gearbox is stuffed.
Providing your rear diff is original and hasn't been swapped out you will have a 1-way plate type LSD rather than the viscous LSD of the 4-bolt E39A's. It is the same center as the Lancer Evo1, the Evo2 onwards went to a 1.5 way plate LSD. I believe the 1.5 way LSD centers can be swapped in no problems. If you had a viscous LSD originally then that's when you would need to swap rear axles or the axle cups at least.
In short the Evo3 RS box and transfer case will work fine in your car - you may have the speedo over-reading though as the Evo3 uses 205/60 R15 tyres stock and the VR-4 used 195/60 R15 tyres, unless the difference in speedo drive output is taken up by the dash cluster alone.
