Hey guys I just got around to installing my lower shores performance boost controller and I have a few questions. What size vacuum hose do you guys use to fit the smaller diameter on the waste gate nipples of smaller turbos like(Mhi big 16g only about 1/8") to fit with larger one on the lsp mbc which is 1/4" I believe? Do you guys use some kind of 1/4-1/8 adapter or do you stretch that 1/8 hose to fit over the 1/4 nipple on the mbc? I can't get the 1/4 inch hose tight enough over the wg nipple or stretch the 1/8" hose no matter how much I pull the damn zip tie so it doesn't leak any suggestions.Thanks
Dunstan.....
Dunstan.....
