onesickcrx
I want to get my Galant's suspension setup the best it can be, with that said what kind of camber and toe settings are you all running?
Lets get a outline too help me as well as others in the future.Say something like this...
:EXAMPLE:
Daily driver = stock camber and toe
Aggressive daily = 1.2 degrees negative camber stock toe
Weekend car = 1.8 degrees negative camber .5 degree of extra toe
Road race setup = 2.3 degrees negative camber .8 degree extra toe
We could list what suspension parts we having installed and how it rides.
:EXAMPLE:
2 degrees of negative camber and stock toe front
1.2 degrees of negative camber and stock toe rear
D2 Coil overs
front and rear Strut bars
Subframe/Mustache bushing kit
Jay racing active rear toe eliminator
Pina chromoly rear camber arm
White line front 22 sway bar
White line rear 26mm sway bar
235/45/17 BFG T/A KDW
Ride is good for weekend car. Performs great in the turns but it eats tires up a little
:EXAMPLE:
:EXAMPLE:
D2 Coil overs
