Larry Parker's old GVR4 brake/clutch pedal set up?
I've searched all over but can't find out which pedal assembly LP used on his rally car. Anyone know if it was a forward or reverse swing mount Wilwood kit? Was it a clutch and brake pedal assembly or just a brake? I found a photo of the engine bay and only see 2 master cylinders. I'm hoping the brake and clutch pedal fit, as the steering column looks like it will cause some headaches.
