Koni Inserts For KYB AGX's : Use 1G DSM Inserts?
BluFalcon
Wichita, KS
I've got a set of 1G DSM KYB AGX's's with Galant specific H&R lowering springs on my car. The fronts are blown (again) and i was thinking about going with Koni Yellows for the fronts, using the AGX strut bodies. I can't find Galant specific Koni Yellow inserts for the VR-4 anywhere, but they still offer them for the 1G AWD's. Since the 1G DSM AGX's are dimensionally identical to the OEM Galant struts aside from the location of the spring perch, these strut inserts should work on the Galant as well, right? I already have Tein front camber plates, and was thinking of pairing the Koni inserts with a set of Ground Control coil over sleeves. Anyone else running a similar setup?
GreenGSX
Rochester, New York
We are using the DSM koni inserts on the One Lap VR4. In fact the entire suspension, minus Curtis's upper rear control arms, came right off my 1992 GSX track car.
