I am getting 43counts of knock at around 2300 and 15% throttle. Tried riching it up still doesn't help. I am running 550s safc and a maf trans. Could this be phantom knock?
Sounds like PK. At that low of throttle and RPM, it's more annoying than anything due to the ECU pulling timing. At WOT/high RPM/high boost is where you don't wanna see a bunch of knock.
Timing is set correctly, I see no knock at WOT have tuned it to around 10.8 to 11 AF. I am only seeing the knock at around 2.5 at 15% throttle, if I hold it at the throttle it will knock until I change throttle position. It also sometimes happens if I change throttle very fast in low rpms but not a full throttle. All of this happens at partial throttle.
My car used to do that just cruising down the freeway. Annoying. I had Keydiver whip me up a chip with PK code to get rid of it. Been good for like eight years now.
I have a brand new sensor. I need to get an eprom before I run the keydiver chips. I am pretty sure that is just PK but I am gunna go get some race gas today and run it to see if it disappears.
