transparentdsm
PART / COLOR / LOCATION
12 VOLT CONSTANT / WHITE (+) / IGNITION SWITCH HARNESS
STARTER / BLACK/YELLOW (+) / IGNITION SWITCH HARNESS
IGNITION 1 / BLACK/WHITE (+) / IGNITION SWITCH HARNESS
ACCESSORY/HEATER BLOWER 1 / BLUE/BLACK (+) / IGNITION SWITCH HARNESS
PARKING LIGHTS ( + ) / GREEN/WHITE (+) / IN DRIVERS KICK PANEL
POWER LOCK / BROWN/WHITE (TYPE B) / @ RELAY BLOCK, ABOVE FUSEBOX
POWER UNLOCK / BROWN/BLUE (TYPE B) / @ RELAY BLOCK, ABOVE FUSEBOX
DOOR TRIGGER/ RED/GREEN (-) / IN DRIVERS KICK PANEL
HORN / GREEN/BLACK (-) / @ STEERING COLUMN HARNESS
TACH / YELLOW/BLACK / @ IGNITION COIL
BRAKE / GREEN (+) / @ SWITCH ABOVE BRAKE PEDAL
ALL OTHER LEFT OVER WIRES SHOULD BE INDIVIDUALLY TAPED OFF AND ZIP TIED OUT OF THE WAY.
I have found the wiring diagram for it and broke it down to this. I will now be ordering a keyless entry system, It's a Audiovox AA925 3-button Remote Keyless Entry System. It's extremely inexpensive and looks small enough to fit inside of the Evo flip keys i am making. I will post pictures of the product and installation as i move along.
