AgressiveVR4
New member
This is my first post and would appreciate any help at all.
The last couple months have been a real bumpy road to ride for getting this JDM Galant VR4 back running after the timing belt skipped a tooth because of a failed hydrualic tensioner.
After many random parts deciding to fail I thought I finally was able too drive the car again after fixing all the worn down 28 year year old parts.
So just as I got the car back from the shop a leak arises not even 2 hours of having it back and its from my front right CV axle seal with quite a bit of play in the green thing beside it /ubbthreads/images/graemlins/banghead.gif
So here are some questions regarding the compatibility of 1G AWD JDM Front cv axles from the RHD GalantVR4 with a 2G AWD USDM K-W5M33-2-NZPT Transmission from an 96 Eclipse.
Will A 1G axle be compatible with a 2G transmission in the application?
If they are compatible, then why does my right side CV axle have 1cm play and a leak? Could it be just a seal? or maybe the whole bearing assembly behind the seal? Is it possible that the axle wasn't seated right? and If that's possible with it still being connected mechanically to the other wheel how can i diagnose / Fix it my self without taking it back to the shop?
If they aren't compatible what Cv axles should I be looking at getting ?
Thanks for any input guys. I'm a newb so I hope this question is okay in this section /ubbthreads/images/graemlins/smile.gif
