intercooler piping, 2.5 in
yubh8tn
coeur d alene, idaho
Hey, I'm trying to upgrade all of my intercooler piping to 2.5 inch, but I don't want to use reducers on the TB elbow or the turbo outlet. It's easy enough to find aftermarket TB elbows, but I cant find a 2.5 inch turbo outlet. Anybody know where to get one?
If not, how should I run my piping so there's not a massive reducer coming straight off the turbo right next to the exhaust?
JNR
ca
You will need to use some sort of reducer on either end...they make silicone coupler reducers, although a longer transition would be helpful on the throttle body side. You'd want to look for concentric tubing reducers in that case and weld to your 2 1/2" tube. Don't forget to put a bead on the exit end, or else risk not sealing or even holding it on (i.e. pop off) under pressure (boost).
