idle at 2000 help please
ok i just built this motor and started it up for the first time its been a while since i played with a 4g63 AND have forgot all the terms used. i tried reading as much as possible that has already been on the forum about grounding the TB and checking vacum leeks and i do not think i have a vacuum leak its all brand new vacuum line and all smog/emissions have been deleted. The car is practically stock. the car wants to idle at 2000 rpms with the biss screw all the way in and the timing fully retarded. but if i just quikly wack the throttle it will set around 600 rpms but about 30 seconds to a minuit later it will raise back to 2000. Im really sorry if this has been posted already but i couldnt find anything. please please help im not quiet sure what everybody means about grounding out the pins to set timing thanks for any help /ubbthreads/images/graemlins/banghead.gif
