Quoting turbophein:
what can we do for the rears?
my right rear caliper starts squealing with any hard type of breaking for a minute or so, pretty sure it is sticking slightly, i had a hard time turning it back in when i repainted my rear subframe.
Other than getting better pads, there is not much you can do for the rear as there currently is not a way to use other calipers and retain the e-brake function. Someone did swap out the rear-trailing arms and such to be able to run the 3000GT brakes in the rear aswell. Appears to be too much of a hassle.
If you upgrade your calipers and rotors, don't cheap out on the pads as you won't see much of a gain. Get some R4-S pads if street driven.
I had Corvette calipers on the HKS 1g that I had before. I will be putting Evo Brembos on the 2g I just aquired. Luckily for the 2g, the Evo Brembos just bolt in.
I have Portefield R4-S pads on my Galant and it bites. I had them on the 2g I had before and also in the 05 STi I use to own, 89 MX6 GT Turbo 4WS that I use to own. Really great pad in my opinion. I will be getting a set for my Evo when the time comes for new pads again. I bought Stop Techs the last time around and they are just okay for DD but don't bite nowhere as good as the Porterfields
