click here
Just want to share what I sow. The only note I add is some are spray copper on the head gasket. also you may have 3 nuts hitting the valve springs. So you can use ARP small collar nuts part# 300-8308. Another thing is you can fit ARP studs with out taking off the head if you are not planing to replace the head gasket. but fit the studs one by one don't remove them all at once.
Good luck'
