Horn wiring help needed
So a friend of mine with a 1g talon picked up some horns from a Toyota supra to replace the weak, meeeep, horn that 1g's have. He is not electrical savvy so called me over for help. I'm not very electrical savvy either and when I ground these horns they blow the fuse.
The talon horn has two wires going to it, the supra horn has one wire. From what I read the Toyota horn uses the bracket as a ground. Anyone have suggestions on making these work? When I give them 12 volts via the battery they blast so I know they work.
When I have the horn not bolted to the car and I plug the power wire in and give a bolt on the horn ground it blasts, but when it's bolted to the car and we activate the horn via the center of the steering wheel the fuse blows. What are we missing?
Thanks
Barnes
Richland, WA
Well, if you want to get that horn working in your cager it's fairly straight forward. The horn you are trying to install draws more amps than the stock horn. Enough extra amps that you are blowing fuses. The only way to *properly* get around this is to use a relay. Use the stock horn wires to activate the relay coil, and hook up the switched connectors on the relay directly to the car battery with a fuse (bigger than the stock horn fuse) and appropriatly sized wire.
/ubbthreads/images/graemlins/rofl.gif i had a feeling i was going to need a relay. is there any way to avoid running a wire to the battery so there's one less obnoxious wire in the bay? Thanks for the response, I appreciate it.
Barnes
Richland, WA
You choices are either a relay, or replace the OEM wiring with bigger wire and a larger fuse. You *could* just use a larger fuse, but that's not considered safe. You run the risk of overheating your horn wire and starting a fire.
Might be worth looking into other horns that are louder than stock, but use less power.
Ok, yeah I am aware that replacing the fuse with a larger one is not a proper fix. We'll see which route he wants to go.
ktmrider
Tempe, AZ
Quoting Barnes:
Recognize for proper use of "cager" LOL. BTW you coulda used Hella ( Hella Tone brand horns ) too.... /ubbthreads/images/graemlins/tongue.gif
Def go the relay route like mentioned, no need to risk an engine bay fire for more noise.
