Hey guys need some help
Hey guys my car won't go in to gear when its on what could the problem be?
curtis
Clarksville TN
Something with the clutch, Has it been slipping lately in 5th then 4th then 3rd? Is the slave and or master leaking?
Report back.
^+1 on the clutch..... just gotta figure out why it isn't disengaging. Could also be your pedal setup.
Well i changed the clutch master cylinder
Yesterday. But when I put it in gear when its off and turn it on and try to move it,
it makes a weird noise and it still won't stay into gear
Here's the link to tell how to adjust the shifter click Just click on shifter and go to the first link.
Its on VFAQ.com which is a site you should learn to use cause it will answer most of your question for you, but.......
if you just put in your Master Cylinder you should know what im talking about:
1) break the set nut loose on the back of the clutch pedal
2) turn the rod that comes out of the master cylinder so that it moves into the firewall
3) test her out and continue adjusting until the clutch works how it should
4) Re-tighten set nut
Along with adjusting the pedal you should be sure the system is thoroughly bled if you just changed out the master cylinder..... even if you did a really good job right when you installed it you should re-do it/check it after driving a bit.
G
zompton
Quoting EvoMR15:
Yeah my master cylinder was leaking
I thought you just replaced it?
Yeah I did I just answered a little bit late
I'm going to replace my slave cylinder now to see what happens
