head stud torque with mitsu mls head gasket
Torque it the same as you would the composite gasket. Go by what ARP says, which I assume you're using since you said studs and nuts.
FlyingEagle
THE Ottawa
Follow the guide depending on whether you use the proper supplied moly lube or other friction modifier.
This can alter the final torque outcome, so ask any questions now. /ubbthreads/images/graemlins/wink.gif
presterone
brunswick maine
I used the supplied lube, from my understanding the torque will be 30.-60.- and then 90ft.lbs as the final turn. Have to wait to torque I think the machine shop fu$$$$ up re installing the valvetrain.
mitsuturbo
Near Seattle, Washington
Quoting yeti:
i would torque to spec. mls headgasket is thinner so maybe a half pound less torque??
The mitsu MLS gasket is, in fact, THICKER than a "stock" gasket. NOT THINNER.
The mitsu MLS gasket MD349347 was released with a TSB stating it was to be used on short blocks which have been decked for a rebuild. That was the original purpose/intent of the gasket.
You can get Cometic gaskets which are thinner, but i've heard mixed reviews about them.
rdomeck
Indianapolis, In.
Quoting yeti:
Why would thinner require less torque? That doesn't make any sense! Follow ARP's guide lines and you will be fine.
yeti
san diego california
Quoting rdomeck:
Quoting yeti:
/ubbthreads/images/graemlins/uhh.gif ...
Well you see my good sir, some times my anus does the talking.
Some would even say I'm FULL OF sh*t.
Noobsauce
Beaverton, Oregon
Yeti with the type of questions you post I would suggest you stick to asking more questions and not giving false information.
As for the torque I would use ARP's recommended torque and sequence.
