GVR4 rear subframe into 1G TEL?
Kenny_Kline
Seekonk, MA
I dropped the rear subframe out of the gvr4 today with intention to be able to use it in my Talon. Obviously the first thing that stocks out is the Talon doesnt have 4ws... or could it? LOL But I will remove the rear steering rack. The Talon also has a 4bolt rear end so I am assuming I can swap my 4bolt setup to this subframe that has a 3 bolt in it, correct?
I want to sandblast this subframe, powdercoat it, put new bushings in it, and swap into the talon with no down time other than a days worth of work. Will this go as I planned?
As I already stated, I plan to powdercoat the rear subframe, put in stock 4bolt rear diff, axles, cups, etc., thicker rear sway bar, new end links, new subframe bushings (mustache bushings, subframe bushings, control arm bushings) and toss it in the car.
What do you think?
THEKID
bergen county nj
it is do able. i had mine powder coated and man what a big difference it makes. the rear bushings can be a pain in the a$$ to remove.
Kenny_Kline
Seekonk, MA
Im not worried about doing the work. Just want to be sure it all bolts up ok.
I am actually looking to lighten up the rear subframe a little bit. These things are heavy! Any suggestions?
THEKID
bergen county nj
yes it will bolt right up. and as far as i know there is no way to lighten it up other than removing the 4ws
Kenny_Kline
Seekonk, MA
Aftermarket arms that are lighter? anything? Even if I could shed about 20lbs off it somehow. It all adds up in the end.
SmoothCustomer
Lexington, KY
Well a TEL rear subframe will be lighter, but I'm guessing you know that and have a good reason for not just putting one in your talon.
Kenny_Kline
Seekonk, MA
I am trying to prevent less down time. Just trying to swap the rear end subframe and be done with it. Not trying to have the subframe out of the car for months.
The gvr4 subframe is heavier because of the steering components that can be removed and thats it, right?
CutlassJim
Manchester, NH
Quoting Kenny Kline:
Yup.
