GSX to VR4 swap
The_Big_Weave
Rapid City, SD
Just picked up a GSX that was an auto and was swapped over to a VR4. The guy who did the swap was going all out, pulled the dash and engine and front subframe harness, the front harness was not put in so I had to put the harness in. The problem I am having is that when I put the harness in there are big white plugs that I can do not fit in the plug that should. I think I put the VR4 harness in but I have the gsx harness and I have not tried it. I have tail lights and brake light, no dash or interior, So I have no idea if I have any interior lights or dash stuff. Problem is that I can not get the car turn over or the blinkers or head lights. I done the neutral safety switch bypass.
I will have pics tomorrow. any info would help.
The_Big_Weave
Rapid City, SD
Got the dash and cluster in and I have lights in the center console and the power locks work. And the security light just stays on even when you turn the key off.nothing comes up on the cluster no matter what I try.
