good lowering springs???????
where can i get good suspension lowering springs for da vr4. not coilovers. springs with a decent drop
curtis
Clarksville TN
Do a search for the evo 8/9 conversion. Theres plenty of info in the how to section. Best bang for your buck and want bottom out and be all screwy probably one of the best things I ever did to the car.
solidviper89
Mission/ San Antonio, Texas
Before the grammar Nazis chime in ill give you a fair warning. The people around here like proper grammar and punctuation skills. We all take pride in having this forum very close knit.
To answer your question, I bought some H&R springs for the galant, and I love em. I can't compare them to evo8/9 springs as I have never been in a galant with those installed.
524of1000
San Antonio, Tx
Evo set up or the H&Rs seem to be the consensus around here. The evo setup is relativly inexpensive, but requires modification to fit. You might find some already setup in the for sale section from time to time, or if you haz teh welding skillz theres a writeup or two in the how to section. Have fun!
Thank you everyone for the advice. Everyone tells me to get adjustable coilovers but they just dont convince on the ride. But ill see what i can do. Thank you again for the advice.
TurboTrader
Pemberton, NJ
I'm way out of the norm and have an Eibach 1g GSX Pro kit springs with a custom 1" spacer in the rear on KYB GR2's. I can't comment on how the handling is as opposed to the H&R, or the Evo 8/9, as I've never experienced either, but I can say, it was quite the improvement and handles great. It's stiff, but not bouncy, and seems to do very well. I have about 11,000 miles on the springs and shocks. Although GR2's are not recommended for use with drop springs, they are still in perfect shape and not blown out or anything of the sort, though if I had it to do over, I would go with AGX's.
The ride height seems to be spot on as well, at least in my opinion, I measured about a 1-3/4" drop all around. I originally toyed with a .5" spacer in the rear, but the back sagged a bit much. The GSX springs are shorter in the rear. The 1" spacer worked well.
cheekychimp
East Sussex, U.K.
Quoting MadBeachDSM:
Mad Beach that's a really clean looking car. Have you got a member's rides post up yet? If not you should do one! /ubbthreads/images/graemlins/worthy.gif
TurboTrader
Pemberton, NJ
Thank you! I haven't as of yet, but when I can round up some free time and all the most recent shots, I will definitely do so.
conquesttsi
Northern Connecticut
Quoting turbofonz:
I have H&R's on my car, and it's not low enough for my (personal) taste.
Did you change your setup? When I saw you 2 weeks ago it looked really low.
turbofonz
Granby, MA
Evo8 struts w/ Tein Stechs in the front, H&R and GR-2's still in the rear. Waiting to get the rear Evo's welded up so I can put them on.
TurboTrader
Pemberton, NJ
Quoting geno:
Have anyone of you given the "eibach sportlines" from http://www.streettunedmotorsports.com/parts/eibach_sportlines_dsm.htm a try? It says 1.5" - 2" for the dsm's. I have a set eibach ?pro? on my talon and i wish it was a bit lower. please provide pictures if you have them.
thanks
Eibach sportlines on a VR-4 would be way too much, I would think. I only have 225 series tires and rub on the front fenders during hard dips/bumps. The Sportlines also don't have much of a desirable springrate even for DSM's, and don't handle any better than the pro-kit from what I have heard. If you really want to be able to go low with little issues, Coilovers are your best bet, pricey, but everyone says they are well worth the cost.
conquesttsi
Quoting turbofonz:
Cool, alot of people have had good luck with that setup. I have agx's now. I think I am going to add h&r springs when I do my 5 lug/4 bolt conversion this spring.
