Specter
So i finally got a 2g maf, and i had a bracket for it. The bracket sits on the maf, the 4 studs go into the four holes the 2g maf has and nuts gets tighten on those studs, and on the other side of the bracket goes an aftermarket K&N intake filter. Do i have to install any kind of gasket between the 2g maf and the bracket, and tighten it? Or is there no need? Just curious if it will suck unclean/dusty air /ubbthreads/images/graemlins/dunno.gif
Thanks!
Thanks!
