Posted by RedTwo:
"MD150427 Is from a pre face lift (pre vents) VR4 or VR4 RS produced between 1-10-1989 and 3-07-1990. Essentially the same parts as the earlier 450cc, TD05H-14B cars.
The AFM/MAF is the same as all US VR4, TPS is the same as the US90 VR4, but the CAS doesn't have a corresponding US part number. ISC is a bit funny as Mitsubishi seem to have replaced all 4G6X ISC units in ASA with a generic part?!?
What is being translated here would be this:
Use a 1G Talon/Eclipse/Eagle MAF
Make sure you have a 14b turbo by reading the numbers on the aluminum case half.
Make sure you have 450cc blue top injectors.
Rewire back to a stock MAF plug configuration per "www.VFAQ.com"
You will then have a HZ signal in the correct range, from the MAF to the ECU for idle and running stock boost.
Get the car running with all stock components, forget the word "tune", and roll down your sleeves because you are now done the hard part.
Drive the car for a while, at least one full oil change worth, and contemplate all the time in life you now have back.
Complete all the basic maintenance for your fluids and timing belt and related components - lots of that stuff located here in the GVR4 writeup for new owners.
I realize this is installed in a J1 Elantra body, but it's all the same stuff in the motor.
Consider modifications after you have gotten this far, start to learn the basic tuning process and move forward.
I hope all the advice I have given is correct, because the guys here drill it into our heads; and with good reason.
We have seen the corner cutters, and way laid projects as a result.
We want you to succeed and therefore have to give some rather particular advice.
It's all in the spirit of vehicular comradery!
