Just elbow grease/clay bar and good lighting for the picture.
Been working on getting things ready to do the turbo motor swap, and some other upgrades. Ended up going to ecmlink since thats what i have on my Talon. Got the manifold to do the evo x turbo fitted, its a tight fit lol. Will be able to use all the factory oil/water feed lines though so thats cool.
Also, figured out the brake setup. I'll be using Focus RS front calipers, focus rear calipers. The calipers are great, and cheap. The fronts are monoblock brembos, very light for the size and ~100 bucks a piece re manufactured. The rears are stock style, one piston and manual e-brake, but they are aluminum bodies so quite a bit lighter than stock. Rotors: ~13.25" front rotor, i'll be using a custom rotor blank and make a top hat. ~12.5" rear rotor, basically a stock ford edge rear rotor (will just need to drill a 5x4.5 pattern and upsize the centerbore).
