fwd non abs same as awd?
dsm10o0
San Jose CA
is the 1g dsm fwd non abs prop valve and lines the same as the awd and would it fit our cars?
fuel
Toronto, ON, Canada
prop valve is a different bias, but you can use the hard lines from a FWD car on the front of the VR-4 to eliminate the ABS. Although, I seem to recall that the prop valve is mounted in a different place on a 2WD than it is on a 4WD Galant, though this could only be for RHD vehicles.
RedTwo
New Zealand
Yeah, all the FWD galants I've inspected have the prop valve mounted to the brake booster. The lines are completely different.
You can still use the FWD prop valve but like fuel said, the bias (front/rear brake pressure) will be slightly different.
Muskrat
Lexington, KY
That may be true for NZ cars, but I seem to recall the last time I looked at a few DSM's in junkyards the prop valve was mounted in the same place.
Go look where your prop valve is and find a car in a junk yard and see for yourself.
You'll need the two lines from the MC to the prop valve, the two lines for each front brake from the pop valve, and the prop valve itself. The rear lines don't need to be messed with.
