Still having some issues with my fuel trims I have managed to get my mid and high trims at just about 100% my low trim goes right back to pig rich 81.2%. problem is I can lean it out a bit by decreasing the fuel pressure(below 37psi my chip setup by keydiver chip)I can get all the trims above 100% but then I get excessive knock either in 3rd gear or WOT up to 14 counts sometimes more. Mods are MHI big16g,fic 850cc,walboro 255 rewired,evoIII manifold and O2 housing,buschur racing 3" turbo back exhaust,aem wideband,dsm logger,new O2 sensor,evo ix mas,aeromotive afpr,keydiver 91-94 ecu for current mods.Only exhaust leak is a small one after my test pipe clamp its also after my wideband O2 sensor. Did a basic boost leak test nothing conclusive I am still reading 18-20hg at idle so I dont think its a vacuum leak the car now pops or backfires under hard acceleration which would signify a rich condition well it goes away when I actually add fuel not when I take away fuel????? My wideband also doesnt change value at idle when I add or subtract fuel just stays at 14.9-15.0. I cant seem get all my trims at 100% or so not have knock or have the wideband read correctly.I am very frustrated the idle part drives me nuts my logger shows 81.2% at idle but my wideband reads 14.9-15.0(good) isnt this contradicting I also notice the wideband reads extremely rich when I lift off the throttle like in the 10's shoudlnt be the opposite. Well sorry for the long post but I am up to my neck in frustration just cant seem to get this thing correct please help thanks......
