How do I hook this up to the battery? I am trying to test my fuel pump and can't figure out what tool to use to hook it up. Do I just use clips from a multimeter or a special connector?
Just use an alligator clip to connect to the terminal. Then, take a wire (I typically use a meter lead) and jump it to positive battery voltage. Once you do, the fuel pump should run.
I literally just did this yesterday. Car has been in the garage for the past four months and I always pressurize the fuel system using that connector before I attempt to start it after sitting for so long.
